smoothing a surface
Hi all Labviewers,
spikes.pngThis is voltage I am getting from an array. This is actually a frame of a 3d-surface video. Is there a way I can ''smooth'' the surface? Any ideas welcome. Thank you for your time
Message 1 of 10
(4,663 Views)
@LambdaDigamma wrote:
Hi all Labviewers,
All those zeroes to me means a very fine resolution.  Do you need that kind of resolution, or can can you change the scale to something more reasonable?
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(4,647 Views)
There are many ways to smooth a 2D set of data. What kind of resolution to you need to retain?
(Try e.g. a 2D convolution with a gaussian kernel of appropriate size)
(In the most extreme case, you would replace all elements with the average of all elements, but you are probably looking for something more detailed).
Message 3 of 10
(4,636 Views)
I think a resolution that will just smooth the spikes and make the surface look more like a sheet with curves
Message 4 of 10
(4,616 Views)
You might try using the graph properties to select a Z-axis range that better suits your needs.  It looks like the graph is auto-selecting the range to give you maximum detail.
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(4,604 Views)
You said this is a video. Does the smoothing need to occur in realtime as the data is acquired or is it sufficient to smooth later?
Can you attach a typical 2D sample array? What kind of structure do you expect to remain after eliminating the high frequency noise?
Message 6 of 10
(4,590 Views)
OK, this is how it looks after the autoscaling takes some time and stabilizes. It is smoother I know but I just want to get rid of the spices and have like a surface covering the spikes like a tangent maybe.
Message 7 of 10
(4,579 Views)
and yes it is a video and the smoothing doesn't have to occur in real time. It can be a post process
Message 8 of 10
(4,578 Views)
I was checking the 2d convolution with gaussian kernels, looks interesting. Can you be more specific? Thank you for your time
Message 9 of 10
(4,559 Views)
You still have not attached any typical dataset.
Message 10 of 10
(4,547 Views)
