How to read an ECG signal from a Del Mar Analysis System?
Does anyone have any experience with reading ECG data from a Del Mar Analysis System with Labview?  I am not sure on the header and data format of the files.
Thanks!
Jenn.
(2,825 Views)
Are you interfacing with a GPIB? Any more details would be excellent. Thanks!
(2,807 Views)
No I am not.  All I have is the raw data files with the following extensions and I am trying to understand how the data is formatted so I can import it into Labview and analyze it:
.ann
.cal
.dat
.epi
.evt
.hdr
.log
.mfn
.mfv
.pat
.st
.sum
Thanks for any help!
(2,790 Views)
You can check to see what the Biomedical Toolkit can import. Otherwise, you will need to get details on the file formats from Del Mar.
(2,788 Views)
Yes - I checked and this file format is not supported by the biomedical toolkit.  This medical portion of Del Mar was sold and I have contacted the new company and little help is available/offered on the file format.  I just thought it was worth checking to see if someone has already cracked the code!
Thanks.
(2,783 Views)
