small project
Hi fan,
@soccerfan wrote:
I did, i converted all the way down to version 9. What version do u want me to converted to?
But the VI attached in your previous message was saved for LV2023.
I prefer LV2019…
Message 21 of 34
(820 Views)
The down-converted version will be in a new folder. The original will be left unchanged, so make sure you attach the correct VI.
Message 22 of 34
(798 Views)
Hi again,
When  i save it to lower version (ver 19). It doesn't save to another file. It doesn't show me any directory to save to. Also when i go to vi property to look for a version it was  saved to, it does not exist., What am i doing wrong.
Message 23 of 34
(785 Views)
By default, it will automatically create a new folder. Look in there.
Message 24 of 34
(778 Views)
Sorry, it does not on my mac pro. what is the default directory so i can go there search for it.
Message 25 of 34
(771 Views)
Hi fan,
On Windows "Save for previous" asks you where to save the VI file(s)…
Message 26 of 34
(764 Views)
I know exactly what you are saying. I am a labview learner but proficient in manipulating directories and files. After i save , a window comes up and asks me what version do i want. i select version 19.0 then save and gone no option of choosing directory. I wonder if anybody have used this option on mac.
Message 27 of 34
(755 Views)
Hello again,
I hope you had a good thanks giving.
I am uploading it again and hope somebody can open it and downgrade it to version 19
Cheers
Message 28 of 34
(734 Views)
By default (i.e. if you don't pick anything specific), it will create a folder next to the original VI. That folder will have the same name as the VI. It should be trivial to find the newest folder and recognize the name!
I would also very strongly recommend to use a more normal file name with a single period as extension delimiter (i.e. not "score app..vi").
Message 29 of 34
(724 Views)
Finally it worked for version 18 but not ver 19 for some reason, I hope you can open it and help me on my real problem. Please no comment on the mess. I am looking forward to using vi i am not aware of.
Message 30 of 34
(712 Views)
