slider
Hi Everyone,
I'm a beginner and newbie to Labview forum. I am trying to produce a Train Driving Simulator using Labview 8.6.
I have attach the file which I am still working on. I have a few issues that I don't seem to solve.
1. The Dead Man's Handle slider is suppose to return to minimum (bottom) position everytime the user 'leaves' the slider.
But as you can see, the slider remains at last position.
2. The target speed is suppose to vary; for eg 10 sec of 20kph, 30 sec 0f 50kph something like that.
At the moment I have fixed it to random number of 79-80kph.
3. After I stop the VI and play it again, the chart continues from the previous values.
The chart screen should clear and start fresh everytime the VI is played.
Also, I think my front panel codes can be simplified but not too sure how.
 Any ideas or advice would be very much appreciated. Thank you.
Message 1 of 8
(5,580 Views)
Hi OSMAN,
i can't open your vi at the moment.
Use a property node of the chart and select "history data", should be the last entry and connect an empty array to it.
Mike
Message 2 of 8
(5,574 Views)
I've accomplished your first point with an Event Structure and Notifier.  Take a look and lemme know if it doesn't help.
Use the Code Capture Tool
Message Edited by jcarmody on 04-15-2009 08:21 AM
Jim
Message 3 of 8
(5,556 Views)
When you say the user "leaves" the slider, do you mean releases the mouse button, or moves the mouse away from the slider?  You'll need to use an event structure to accomplish this; look at the Mouse Up and Mouse Leave events.  When you receive one of those events (which one depends on the behavior you want), you can use a local variable to reset the value of the slider to 0 (or whatever the appropriate value is).
For the variation in target speed, you could use the "Elapsed Time" Express VI (I don't usually like express VIs but in this case it's probably the simplest solution).  You can feed the amount of time in seconds as an input; configure it to reset automatically when the time is reached.  Whenever the "Time has Elapsed" output is true, set a new speed and a new target time, both of which you'll want to store in a shift register.
Message 4 of 8
(5,552 Views)
Hi Jim,
Thank you for helping me with the Dead Man's Handle.
Yes, the handle does return to zero now. I have amended it to drop to -15 (bottom position). However, I placed a probe at the slider output going into the case structure, I notice that as I move the handle the value changes but when I hold the handle stationary or reach the top position, the value becomes zero. This causes the speedometer not to 'accelerate' anymore. Is there any way to overcome this?
Rgds.
Message 5 of 8
(5,534 Views)
Accepted by OSMAN
Try this modification to jcarmody's version; it eliminates the notifier and should solve the problem.
Message 6 of 8
(5,523 Views)
OSMAN, nathand's solution is better than mine.  I never think to use events like that, although I'm familiar with the concept.
One thing I couldn't overcome is the behavior when you move your mouse away from the control without letting go.  It doesn't trigger the Mouse Up event and the Dead Man has rigor mortis.
Jim
Message 7 of 8
(5,516 Views)
Thanks Nathand!! Thanks Jim!!
Just what I needed. Smiley Very Happy
That leaves 2 problems out of 3. Still trying out the recommendations from the others.
Best Rgds.
Message 8 of 8
(5,511 Views)
