slider indicator
      I wanted to know is there a way to make a slider indicator scale run continously with constant data, as shown in attachment below . If so how to do it ?
Message 1 of 19
(4,740 Views)
What do you mean, run continuously, with constant data? Your attached image doesn't clear up the question. If you mean smoothly, it is a matter of sending the indicator small increments, to get it to move small amounts. While it is  an "analog" display, it is also discrete.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 19
(4,738 Views)
      In my project i get some constant values for a short period of time and then it changes to different value for another short period of time. For eg, the slider can diplay 1 2 3 4 5, but the problem is that if the data is 4 4 4 4 or 2 2 2 2 the pointer stucks at 4 or 2 and the scale doesn't move continously. In my project i need to show the mvement of 4 4 4 4 or 2 2 22 or some other constant data.
Message 3 of 19
(4,735 Views)
How do you expect the slider indicator to behave any differently from the data you send it?  If you send a 4, it will display it as 4.  If you send a 2, it will display it as 2.
If you don't like the data you are getting from wherever it is you are getting them from, that is a completely different question.
Message 4 of 19
(4,731 Views)
       If the first value is 4, second value is 4 and third value is 4. Is it possible to diplay in a continous manner but not display only the first value?
Message 5 of 19
(4,726 Views)
use chart or graph
Message 6 of 19
(4,709 Views)
A slider only displays 1 value at a time.  So what do you want to display instead of the first number?
Message 7 of 19
(4,701 Views)
If you have consecutive 4's, it's not showing the first 4, but the last (current) 4. Is there some way you know it's the first 4?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 8 of 19
(4,693 Views)
        I wanna display it like a time scale but with constant values,which i get from a another subvi.  the past values should also be diplayed below either if it is a constant or not. I cannot use graph or chart. Is there any other way to do it?
Message 9 of 19
(4,647 Views)
Hi
if you want to see the past values also, graph or chart is the way to go..slider is a numeric indicator/control that can have 1 value at a time.
else, you can have an array of numerical indicators which get updated with new value either at index 0 or at the end of the array
but, graph/chart would be better
edit: why could you not use graph/chart? they will also give you the time axis!
Regards
Freelance_LV
TestAutomation Consultant
Message 10 of 19
(4,636 Views)
