sir i am using datasocket read ,i am communicating with java but my problem is that bcz im using while loop to see if value has changed my labview consumes all the processors time ,sir i want a event like thing so that while loop is not in continuous loopHi Sam,
I want to pass along a couple of tips that will get you more and better response on this list.
1) There is an un-written rule that says more "stars" is better than just one star. Giving a one star rating will probably eliminate that responder from individuals that are willing to anser your question.
2) If someone gives you an answer that meets your needs, reply to that answer and say that it worked.
3) If someone suggests that you look at an example, DO IT! LV comes with a wonderful set of examples that demonstate almost all of the core functionality of LV. Familiarity with all of the LV examples will get you through about 80% of the Certified LabVIEW Developer exam.
4) If you have a question first search the examples for something tha
t may help you. If you can not find an example that is exactly what you want, find one that is close and post a question along the lines of "I want to do something similar to example X, how can I modify it to do Y".
5) Some of the greatest LabVIEW minds offer there services and advice for free on this exchange. If you treat them good, they can get you through almost every challenge that can be encountered in LV.
6) If English is not your native language, post your question in the language you favor. There is probably someone around that can help. "We're big, we're bad, we're international!"
Trying to help,
Welcome to the forum!
Ben
