single samples for loop daqmx
I'm trying to sample a burst of samples at one time, I have set up a DAQmx READ vi in a FOR LOOP and have it set up for single samples and tied the N of the FOR LOOP to a control so I can vary how mayny times it samples... but my problem is that I can't go past 100, it works fine until N > 100.  I don't know why.  This is my error message, my vi is included.
Much Thanks
Possible reason(s):
Measurements: Attempted to read a sample beyond the final sample acquired. The acquisition has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample acquired. The final sample acquired can be determined by querying the total samples acquired after an acquisition has stopped.
Attempted to Read Sample: 100
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Task Name: Voltage_1
(3,035 Views)
I cannot reproduce the error. I ran it with number of samples = 10000. Since you are using a task in MAX and no one has any idea how you've setup that task, why don't you do everything in the VI instead (channel select, range, timing, etc) so that information is available? I suspect you've got something wrong with the timing.
Not sure why you are acquiring data in this fashion anyway. You have no control over the sample rate. You aren't even attempting to set the sample rate, for that matter.
(3,029 Views)
Hi Monse,
what happens when you use "DAQ Read, 1Chan NSamp" instead? Can you aquire more than 100 samples then?
(3,024 Views)
