sin(wt) function in formula node
How to create a function in formula node and plot it for Vo vs t
V = Vo * sin(wt)
with frequency = 50Hz
Vo = -350 to 350
Nghtcwrlr
(5,176 Views)
Why a formula node? Just use plain LabVIEW!!!
Your specifications seem odd and incomplete. What is the range of t you want? "Vo vs t" only makes sense if V=constant unless you want a 3D or intensity graph: V(Vo, t).
Please clarify!
(5,161 Views)
t = 0 to 100
I need an intensity graph: V(Vo, t).
I need to use a formula node because i want this result to use in aniother equation.
Nghtcwrlr
(5,157 Views)
This is probably related to this.
(5,152 Views)
