How to create custom default XControl
I would like to have a custom default XControl, implementing the everused state and data, and methods.
I have tried modifying  \resource\Framework\Providers\xi\xctl.llb but I am unable to do anything with the controls of every vis inside. I guess this is some kind of lock, is there any way I can go around it ?
(3,271 Views)
Don't try to modified LabVIEW library, make a copy if you want to add some features to your controls.
I suggest you to read Creating New Front Panel Objects with LabVIEW XControls
(3,247 Views)
The problem is that it is not quite clear how to reuse some design patterns developed for XControls for new XControl, without using copy and paste.
Ton
My LabVIEW Ideas
(3,229 Views)
I have half solved my problem : even if the control types are not the right one, I wire them in the template vi as if they were, and I have changed the data.ctlt to fit my data (i.e. : an object belonging to the class 'FrontPanel'). I have mainly broken wires in the template, but it becomes all right when I create a new xctl since the controls are automatically replaced.
The last missing parts are the methods and properties I would want to automatically create each time I create a new XControl. I guess that it would be more work to do this automatically thant to make it manually...
(3,224 Views)
