simulation interface toolkit?
OH..sorry...the pics cause your misunderstanding...
Pic of 2013 just a previous versions install screen form(http://digital.ni.com/public.nsf/allkb/E37B8A669CF7FD2E86257A5B006C6600)
Pic of 2014 is my installation process..........
I want know why the install process different between 2013 & 2014...
I want install 2014 Model Generation...How find it??
I download form ( http://www.ni.com/gate/gb/GB_EVALVERISTAND/US ) ,it's a full develop version..
Thanks a lot
Message 11 of 32
(3,895 Views)
Oh, thanks for clarifying that Smiley Happy
I downloaded the 2014 Evaluation installer on my machine and found that you have to choose this option on the main page:
In order for the installation process to show you this page:
Otherwise it just chooses the standard features and doesn't let you include the Model Framework!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 12 of 32
(3,887 Views)
Smiley Very Happy
Message 13 of 32
(3,884 Views)
Hi...thanks your explanation..
I already install success,in matlab I try build a .so
It response an error...
I had install C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2013 that provide by NI
( http://www.ni.com/download/labview-real-time-module-2013/4286/en/  )
Error Message:
(C:\Users\LAN\Desktop\test\2014 labview matlab test\LabView_RT_DCBus_3_niVeriStand_Linux_ARM_32_rtw>C:\VeriStand\2014\ModelInterface\tmw\toolchain\Linux_ARM_32_GNU_Setup.bat   && cs-make -f LabView_RT_DCBus_3.mk  GENERATE_REPORT=0 NIDEBUG=0 NIOPT="Default" OPTS=""
Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed.
### Real-Time Workshop build procedure for model: 'LabView_RT_DCBus_3' aborted due to an error.)
NI Linux Real-Time, Eclipse Edition "2014"====>>is the issue point ??
Message 14 of 32
(3,873 Views)
You'll want the 2014 eclipse package (your link was for 2013):
http://www.ni.com/download/labview-real-time-module-2014/4846/en/
Here's a tutorial for setting it up:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHR7CAO&l=en-US
Message 15 of 32
(3,862 Views)
Oh and, what cRIO are you using?
Message 16 of 32
(3,859 Views)
I use cRIO 9068,
I builded a simple .so file using (C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2013) and depolyed it to 9068 success!!
But the file is easy .c & .h ....and I manual generate the .so by  Eclipse Edition...
I want use more complex file that like mdl converts..
I see the labview help (MIT can convert a mdl to .so file)
I think.. If solve the matlab compiler link Linux,maybe it would be ok!!
Really thanks for your reply.....!!!!
Message 17 of 32
(3,837 Views)
I will download the Eclipse Edition 2014 ,and try aganin!!
Thanks a lot!!!
Message 18 of 32
(3,833 Views)
Hi...I already generate .so !!Thanks a lot!!
It possible be used like dll in SIT??
I want call .so like dll,must import the .so but I don't have .h file(because generated by matlab & eclipse).
I reference the paper ( http://www.ni.com/white-paper/2818/en/  )
Message 19 of 32
(3,820 Views)
If the .so is built with the model framework you're going to want to call it from MIT. Check out one of the examples about calling and executing a model in the example finder.
I don't think the shared library import tool is going to work for this, especially since you don't have a header file. You should be able to call the library from a call library function node directly if you really need, but again if this is a model you should be using the MIT functions instead.
Message 20 of 32
(3,805 Views)
