simulation interface toolkit?
Hi all..
I installed LV2014 & Model Interface toolkit..but I can't find the SIT function in Tool Menu,
Where can I install SIT??
thanks!!!
Message 1 of 32
(9,049 Views)
Accepted by topic author hsinhsiang
Simulation Interface Toolkit used to be the toolkit that you used to call models, but since LabVIEW 2013 it has been replaced by the Model Interface Toolkit.
https://forums.ni.com/t5/NI-Blog-ARCHIVED/Farewell-LabVIEW-Simulation-Interface-Toolkit-Hello-LabVIE...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIlMSAU&l=en-US
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 2 of 32
(9,017 Views)
Hi Sir...
I need convert .mdl to Linux .so,I installered Veristand but can't find "NI VeriStand 2014 Model Framework".
I re-installer again,I didn't find NI VeriStand 2014 Model Framework as the feature to install.
download path
http://www.ni.com/gate/gb/GB_EVALVERISTAND/US
Where can I find "VeriStand 2014 Model Framework" install??
thanks
Message 3 of 32
(8,966 Views)
Are you trying to run models on a Linux-RT target with the model framework?
When installing VeriStand to a Windows Dev machine the features page of the installer should include a model framework option.
Message 4 of 32
(8,946 Views)
Thanks your reply....
I can't find NI VeriStand Linux_ARM 32.tlc that like below path description
http://zone.ni.com/reference/en-XX/help/374160B-01/vsmithelp/mit_convert_model_to_dll/
If I install success ,the License manager should have a Generation model toolkit,but I didn't see it!
In Matlab I had setting path..
Message 5 of 32
(8,939 Views)
Help show the needed install feature,but 2014 installer didn't find...
Message 6 of 32
(8,934 Views)
Linux model support is a feature of the 2014 version, it did not exist in previous versions. It looks like you're using 2013 SP1 in the screenshots.
Its noted in the new feaures section on this page:
https://www.ni.com/pdf/manuals/modelInterface_2014readme_KB.html#New
Note: while MIT 2014 does support running models on Linux RT targets the VeriStand 2014 engine does not support Linux RT yet.
Message 7 of 32
(8,926 Views)
I'm using veristand 2014!!
In fact I just want using MIT to convert MDL to (.so)...
Message 8 of 32
(8,919 Views)
Message 9 of 32
(8,911 Views)
Ok so this is confusing.
Here's your screenshot, with some more boxes highlighting that you're actually installing the 2013 version:
I'm looking into why the "VeriStand 2014" Evaluation version includes 2013 SP1...
Message 10 of 32
(8,904 Views)
