09-22-2008 05:10 PM
Hi
I want to use simulate arbitrary signal express vi in my application to create array of data to process. With this expresss, vi if user want to define a signal he has to go to block digram and double click the express vi. But i want to have data tabe in the front panel so user can define signal in front panel. i dont want user to go into block digram and bouble click the express vi to define the signal. i would like to have that in the front panel so user don't have to go into the code. Is there any way i can so this?
09-22-2008 06:41 PM
09-23-2008 10:34 AM
Thanks for the reply. My 2D array contains time and data.
t
09-23-2008 10:44 AM
09-23-2008 11:03 AM
09-23-2008 11:15 AM
Could you please tell me how to locate the source code for simulate arbitrary signal express vi ?
09-23-2008 11:17 AM
09-23-2008 11:38 AM
The one i need to look at is password protectd. ex_TableInputs.vi cannot be opened. Is there any other way?
09-24-2008 01:23 PM
Hi Suni,
To open the source code for an express VI you should just right-click on it and say "Open Front Panel". That should open the front panel and block diagram. Hope this helps.
Ipshita C.
