simple popup control message
I need to make a simple user instruction message
popup just prior to execution of a sequence with a simple yes/no booleen button in it or even a simple popup message that can be clicked on to remove. Thanks
(2,770 Views)
What's wrong with the "Two Button Dialog" found in the Time&Dialog palette? 😉
Should work just fine for this.
(2,770 Views)
you can use "One Button Dialog.vi" and "Two Button Dialog.vi" from "Functions->Time & Dialog" palette.
Good luck.
Oleg Chutko.
(2,770 Views)
