%,; signifier problem with LabVIEW 8.5.1
Good afternoon,
I wrote a software under LV 8.2 which uses format code to customize display with , or . decimal point. So I use the following format : %,;%.3f or %.;%.3f depending on user settings.
When I convert the software under LV 8.5, using those format produce errors. I cannot format my display any more. The problem remains also when a new VI is build under LV 8.5 (without converting).
I attached a test VI to this post to illustrate what I mean. The VI is written under LV8.2 and works well. Under LV8.5 you will have an errror.
Knows anybody a solution to that problem?
Thanks in advance.
Adelina
PS: I post this problem in a wrong thread... Sorry.
(3,948 Views)
This looks like a bug.
Using 8.5.1, the %,;%.3f works fine, but %.;%.3f generates an error.
(even if you enter the advanced format directly in the property box, %.;%.3f gives the red LED, indicating an invalid format.)
(3,938 Views)
In my german environment, both format does not works. I agree that it looks like a bug...
(3,931 Views)
Are you using 8.5 or 8.5.1. Just curious if there could be a difference.
Anyway, I posted a link to this thread over in the bug thread, so hopefully we get a CAR#
(3,926 Views)
I am using 8.5.1 in german version.
Thanks for posting the thread!
(3,922 Views)
I could also reproduce this error :
  • decimal point = , --> OK with 8.2.1 and 8.5.1
  • decimal point = . --> OK with 8.21 but KO with 8.5.1 !
(3,921 Views)
This was reported to R&D (#118826) for further investigation. Thanks for the feedback!
District Sales Manager
(3,848 Views)
