signal analysing program faces different signal processing errors while the mentioned settings in the error solutions are correct!!
I am trying to get 4 signals from my bluetooth  which is connected to a sensor. later on I need to analyze the signals for calculating heart beat and blood oxygen saturation. when the labview reads the data it has no errors but anyway the peak detecor doesnt work. my sampling rate is 100. anyway I get different signal processing errors like 20023 and 20037 and 20041, 20015. but when i check the solutions for the errors, they dont help me at all. like error 20023 complains about low and high cut of frequency while mine is set correctly could you please check it for me 😞
(3,037 Views)
Mistaken wiring here- after BD Cleanup (Ctrl-U)
Error -20037 occurred at an unidentified location
Possible reason(s):
Analysis:  The number of data points in the Y value array must be greater than the order value.
"Should be" isn't "Is" -Jay
(3,012 Views)
