show value every 10 seconds
 I am trying to create a moving average for the data I am collecting. I have managed to implement the movingaverage.vi into my program, but now I want to display the actual value on the front panel but only once every couple of seconds (at the moment I am collecting data many times a second and this is too quick to read on the front panel). Is there an easy way to do this?
(4,170 Views)
Accepted by topic author Lun13
Place the indicator inside the true case of a case structure and set the case to true once every 10 seconds.
(4,168 Views)
There might be examples of this on the forum.  The easiest implementation is to use a State Machine, where you enter the "refreshDisplay" event at timed interval.
Have a look at the attached example.
R
(4,166 Views)
Thanks for the replies - how do I set the case structure to be true every 'x' seconds? I have attached the vi I have so far.
(4,151 Views)
use elapsed time vi.
reset it after every 10 sec as per your requirement
Gaurav kSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,146 Views)
Thank you - does exactly what I wanted!
(4,143 Views)
