show hidden controls and indicators
Hi all,
i have a problem with some controls and indicators i just click right and i press show control or indicator but when i run the VI they hide again .
Any help please
Message 1 of 13
(3,978 Views)
This means there is something in your code that actively hides them (e.g. property nodes). Since you did not show us any code, we cannot tell. If you can't figure it out, attach your VI and tell us which controls are giving you trouble.
Message 2 of 13
(3,974 Views)
Message 3 of 13
(3,973 Views)
Hi ,
sorry i can't share the VI it's confidential but i check my property nodes and it's visible for all controls so any other ideas please to this problem .
PS : i'm using these controls in a event case as value change
thanks
Message 4 of 13
(3,911 Views)
In your picture, you are setting all these Visible properties to TRUE manually, which implies that you are setting them explicitly to FALSE somewhere else.  I don't have a Magic 8-ball like some people here, but I'm willing to make a guess that sometimes that comparison is FALSE and stays that way so they never become visible again.
For all I know, the code that sets them to FALSE is inside the case structure, itself.  But I'll never know, because you just uploaded a picture and not the VI.
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(3,896 Views)
thanks for the response ,this is the subVI
Message 6 of 13
(3,891 Views)
Thanks for showing us your code.  It really helps!  Unfortunately, I don't think there's anything really wrong with it programmatically.  You should look at the various evaluations you use to determine which case fires for each case structure.  Maybe one or more are incorrect, or maybe the incoming data to be evaluated is not what you are expecting.
It's not going to be easy.  I wrestle with this kind of stuff from time to time, and there's no substitute for getting your hands dirty digging into the code.  It seems that the code is pretty well organized, from what I can see, so hopefully it's not so daunting a task.
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(3,882 Views)
Does that breakpoint fire?
Set a breakpoint on the entire VI so that you can watch it execute. If it is being invoked from someplace in your code that you do not expect...
Please note that when a VI hits a breakpoint the "Font Dialog Dropdown" turns into a call chain indicator that you can use to figure where the VI is being called from in the application.
Ben
Message 8 of 13
(3,875 Views)
Ben
Really!!?  I never knew that!!!  Thanks for the insight.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 13
(3,870 Views)
?  it posted to the wrong place
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(3,868 Views)
