show block diagram programmatically?
I'm almostSmiley Wink sure that I did this once and then took it back out.  (the "show block daigram" case in the Menu Selection choice of an event structure is still in my code).
Anyway, I often start a program that runs for hours and then realize that I need to open subVIs or probe some wires.  Since these programs have run-time menus I don't have the option to open the diagram once the VI is running.  Is there a way to programmatically open the block diagrams window when a VI is running?
K
Message Edited by NIquist on 09-20-2007 03:39 PM
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 1 of 12
(8,334 Views)
See reply #29 in this thread.
Ben
Message 2 of 12
(8,314 Views)
I'm intrigued.  I found the code which did showed the Block diagram, but I cannot find those properties in the VI class.  I went back to 7.1.  Are they hidden somewhere I am not seeing, or is there something else I am missing?
Message 3 of 12
(8,304 Views)
Go to the LAVA forums and look at the VI Scripting forum for the full story.
___________________
Try to take over the world!
Message 4 of 12
(8,298 Views)
Thank you.
Message 5 of 12
(8,296 Views)
@Matthew Kelton wrote:
Thank you.
Here's the Link to the scripting forum.
Michael Aivaliotis
VI Shots LLC
Message 6 of 12
(8,271 Views)
Scripting is slick ! Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 12
(8,262 Views)
very sleek !!
check this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=79506#M79506
where PJM shows nice application how to use scripting.
progammatically change code.....hoooo......
... And here's where I keep assorted lengths of wires...
Message 8 of 12
(8,253 Views)
Shhhh......
Its a secret.
But now that you know then you can appreciate the beauty of these items.
The ini used is one of the few time that LabVIEW programmer cares about proper syntax.
OR (to take this analogy way to far)
It is THE "G-String"
Ben
Discalimer: I am a Premium LAVA Member Smiley Wink
Message Edited by Ben on 09-21-2007 07:26 AM
Message 9 of 12
(8,239 Views)
hem hem...
has anyone bought it?
Message 10 of 12
(8,231 Views)
