shifting strings
I am new to LabView please be patient. I have a binary number that is represented by a string. I want to shift this 16 bit number and fill the leading bits with 0's. Will I have to split this string? I know arrays can be shifted n number of times but cannot find this type of shifting for strings.
(4,264 Views)
There are shift functions but only for actual integers not strings
(4,262 Views)
Is there a way to split the string in uneven proportions?
(4,260 Views)
Accepted by msmith1955
Yes, there are lots of string functions available to you. Look in the string pallete and you will see there are functions to split strings. However, since you are really maniulating numbers you might find it easier to convert the string to a number, manipulate it and then format it into a string. Doing it purely in a string will be nontrivial to say the least.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,254 Views)
As Mark said, convert to number, shift and convert back to string.
Ben64
(4,247 Views)
Thank you for the information.
(4,239 Views)
