sharing data between 2 versions of labview
I'm trying to get data from LabVIEW 2014 with 2018. I used shared variables to do so but it's impossible for me to find the variable shared from 2014. I'm looking for another solution or maybe a way to make it work.
(2,575 Views)
Accepted by nandi.nandi
Besides "why would you want to do this?", I recommend checking the network communication methods that LabVIEW has; since they provide connectivity between application spaces (i.e. two executables or LabVIEW versions).
(2,499 Views)
I think you can use VI server between LabVIEW versions, so you could probably use that to read/write the value of some globals. Standard warnings about using globals, blah blah blah.
(2,490 Views)
Thank you my mistake was that I was using globals the wrong way. But I found the proper way to use them
(2,430 Views)
