shared variables
I have an application (LV2013) that uses shared variables on the network.
When I build the application and I install it on the PC where I have developped it, the variables are properly distributed and accessible over the network.
When I install this application on another PC (without Labview), the variable distribution service sends an error message and the variables are not running (pj err_Labview.png).
Do you have any idea on what I could forget to do?
Thank you.
Message 1 of 12
(5,599 Views)
Check you have installed LabVIEW Run Time Engine (it contains Shared Variables Engine SVE)  in your other PC. Check the version you're using in your development PC in MAX. Hope it helps.
Message 2 of 12
(5,590 Views)
How how many shared variables are we talking about?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 12
(5,586 Views)
Thank you for your answers.
I don't have the Labview runtime installed by myself. I thought it was the installer's job. I will try to install it.
We are talking about 5 shared variables.
I'm going to try this and I come back.
Thanks.
Message 4 of 12
(5,559 Views)
Thanks.
Message 5 of 12
(5,554 Views)
Well with only 5 being used, an alternative might be to not use shared variables. You can get the same functionality using a combination of VI Server and FGVs.
Mike...
LabVIEW Champion
Message 6 of 12
(5,533 Views)
Bruno,
I would also make sure your NI Variable Engine service is started.
Message 7 of 12
(5,511 Views)
Thanks for your answers.
Effectively you have to install by yourself the runtime... All is working well now.
Other question : what is the difference between the absolute and relative reference mode for the shared variables ?
I'm also going to take a look using the server, do you have an example for me Mike ?
Bruno.
Message 8 of 12
(5,493 Views)
I found the following in our help documentation, which I only say becuase I forgot that this was an option
https://www.ni.com/docs/en-US/bundle/labview/page/reading-and-writing-shared-variables-with-shared-v...
An absolute Shared Variable node always connects to the shared variable on the target on which you created the shared variable. Shared Variable nodes are absolute by default. If a VI contains an absolute Shared Variable node and you open the VI on a new target, the VI breaks because the node attempts to connect to the shared variable on the target on which you created the shared variable. Use absolute Shared Variable nodes when you do not expect to move VIs and variables to other targets.
A target-relative Shared Variable node always connects to the shared variable on the target that runs the VI that containing the Shared Variable node. If you move a VI that contains a target-relative Shared Variable node to a new target, you also must move the shared variable to the new target because target-relative Shared Variable nodes can connect to shared variables on the local host only. Use target-relative Shared Variable nodes when you are accessing shared variables on the local host and you expect to move VIs and variables to other targets.
Message 9 of 12
(5,468 Views)
Start here:
http://www.notatamelion.com/2015/05/25/using-vi-server-to-interact-with-executables/
The specific example shows using VI Server to fire a remote UDE, but the process is the same for writing to or reading from a FGV.
You might also find this helpful:
http://www.notatamelion.com/2014/12/22/when-are-udes-not-the-right-answer/
Mike....
LabVIEW Champion
Message 10 of 12
(5,456 Views)
