‎10-28-2011 08:58 AM
Hello, I'm new to Labview and looking for help in building a simple circuit. Here is what needs doing:
Essentially when I press a start need the circuit to allow for 2 things- 1. to begin taking data from an NI-DAQ and 2. for a stop watch to start. Then I need to take these 2 sets of data, the data from the NI-DAQ and the stop watch time, and convert them into an excel file where results can be read off.
I need it to measure the NI-DAQ continuously, but only give results to excel every second, along with the time (every second). Then when I press a stop button this all needs to end.
Many thanks,
Jacob
‎10-28-2011 09:03 AM
Post your code (it's not a "circuit", it's a program) so we can see where you are getting stuck. We can't help with just your description except to code it for you and this sounds like a school assignment.
‎11-02-2011 04:44 AM
Hey Furret
As said if you post some code we would be happy to point you in the right direction.
To start off though here is the first part of a tutorial on how to write to an excel file using the report generation toolkit in LabVIEW
Creating a Report in Microsoft Excel Using the LabVIEW Report Generation Toolkit: Part 1
http://zone.ni.com/devzone/cda/tut/p/id/3179
at the bottom of that page are the links to the rest of the tutorial. hopefully this will give you a starting point
Matt
