09-18-2019 07:15 PM
is there a way to set the "source date/time" and "source name" properties of a TDMS file in LabVIEW 2016? Win10
09-18-2019 07:46 PM
11-06-2019 06:06 PM
how would this change if I'm trying to set the properties while the file still resides on the PXIe? The PXIe controller is using LabVIEW RT 2016.
11-06-2019 06:41 PM
11-07-2019 03:11 PM
as you can see from the PNG file, I've done that. I know that the file contains data and that it get FTPed from the PXIe to the PC Host. But the change in properties at the PXIe side doesn't seem to happen. I know that the Shared Variables have data because I've check the contents in the Distributed Sys Mgr.
11-08-2019 01:16 AM
The snippet you show here has a couple of things that I'm curious about, but perhaps they're not your problems. Maybe you can explain them and I can try understand better:
11-08-2019 10:56 AM
yes, I am setting the description, title, and storage date/time the same for an array of TDMS files and closing them. The data in the files is collected before the properties are set. Therefore, closing them after setting the properties should not be a problem. After the main VI on the PXIe has stopped running, then the files are programmatically FPTed to the PC Host. In that process the filename is changed. Does this reset the properties I previously set?
11-09-2019 12:45 AM
I don't believe that should cause a problem (although the filename is used as a property that was previously mentioned, "sourceoriginalname").
I was more checking this bit (quoting disappeared on my computer so copying below...):
I.e. that you are sure the files are closed having had their properties written before you copy the files. If you're sure that's the case (they're copied from disk after they're fully written and closed) then I have no further suggestion. Perhaps if you shared some more of the code someone here might see something, but I don't know where to suggest your problem is.
