set what printer to use for printing
I am writing this program that prints an excel sheet.
I have to use pdf creator to save file in pdf, then using pdf creator to print to another printer right after saving.
BUT pdf creator is not alligning my paper correctly.
I want one of my subvi to select another printer that is not my default printer. I set the default right now as pdf creator.
is there a way to do that?
thank you in advance!
Krispiekream
Message 1 of 10
(4,293 Views)
Message 2 of 10
(4,292 Views)
i tried looking, but i didnt find any solution to my problem on this forum yet.
i am using labview 8.5.
the query available printer.vi is not found?
Message Edited by krispiekream on 07-29-2009 05:13 PM
Krispiekream
Message 3 of 10
(4,285 Views)
That property is available in 8.5 as well.
I have no idea what you're talking about. Are you talking about this VI:
http://zone.ni.com/reference/en-XX/help/371361D-01/lvreport/query_avail_printers/
The VI is in the Programming -> Report Generation ->  Advanced Report Generation palette. Use the Search button in the functions palette.
Message 4 of 10
(4,277 Views)
OK. Now I have NO clue what you're doing or talking about. You went back to edit your post and included two VIs that are using some ActiveX class (what are these for?), and even marked your response as the answer!
Message 5 of 10
(4,273 Views)
i tried looking for the advanced report generation pallete but my labview 8.5 doesnt have that vi in it.
i was just going to use the two vi i found in this forum to get a list of printers i currently have.
select the printer i want to be the default printer momentary. Then in the end of the routine, change back the old default printer and close the vi.
i think its using active X but its alright. i am using activeX to print my test data so its fine using it.
i think its a solution.
i havent tried it yet.
i will do it right now..
Message Edited by krispiekream on 07-30-2009 10:20 AM
Krispiekream
Message 6 of 10
(4,237 Views)
I don't quite understand this. Did you search for the VI using the "Search" button in the palette? You're using ActiveX, so you're clearly running Windows, so it's not an issue of that VI not being available due to being on a different operating system. Do you have a Report Generation palette? This is where it is:
Note that the Printing:Available Printers property returns the same information:
Message Edited by smercurio_fc on 07-30-2009 10:34 AM
Message 7 of 10
(4,232 Views)
haha..opps..i am using on my notebook is labview 8.5.
my testing development i am also working on is using labview 7.0.
i have to use 7.0 and it doesnt have it.
sorry about the confusion. But, I'll try using the activex pr.printers that you mentioned. I should get the same results.
Message Edited by krispiekream on 07-30-2009 10:55 AM
Krispiekream
Message 8 of 10
(4,229 Views)
Accepted by topic author krispiekream
Well, now things make sense. Both the Printing:Available Printers and Printing:Default Printer property are available for 7.0, so you don't have to resort to ActiveX. The ActiveX will probably work. Ultimately it's your choice.
Message Edited by smercurio_fc on 07-30-2009 11:08 AM
Message 9 of 10
(4,215 Views)
Cool.
You have been a great help!
Thanks!
Krispiekream
Message 10 of 10
(4,209 Views)
