07-25-2005 02:25 AM
07-25-2005 03:13 AM
Hi
If you right-click one of your property-nodes (pr.defaultprinter) and select help for printing:defaultprinter, you will see that this information is just valid in the LV-environment. The system is not affected by these properties.
Thomas
07-25-2005 03:21 AM - edited 07-25-2005 03:21 AM
so, if I use the method "Print Panel to Printer" I can change the default printer (in LV environment) as I want (I checked), but if I use the Print HTML Report (which send print command from a browser) this is impossible.
Correct?
No solutions?
Message Edited by vix on 07-25-2005 10:22 AM
07-25-2005 03:34 AM
07-25-2005 03:44 AM
What do you mean with "Print HTML Report"? The standard report vis?
If yes - there should be able to pass the printer you want to print to.
07-25-2005 04:13 AM
07-27-2005 02:56 AM
I found the documentation on Microsoft Web Site: the registry is
HKEY_CURRENT_USER
Software\Microsoft\Windows NT\CurrentVersion\Windows
Device
I wrote a small VI and it works well (on Win XP)
01-24-2008 12:47 AM
01-24-2008 06:32 AM
I'm not able to completely understand what do you mean.
@vettle wrote:i want to set the size of the printer,and it can be setted,but actually it have no active.
01-24-2008 06:55 PM
