set PID gains programmatically
Hi all!
Is there a way to set the PID gains programmatically? I don't need to find the correct values. I already know them. The thing is that every time the system restarts, it seems to reset the parameters entered in MAX. Thanks in advance.
(3,808 Views)
could you indicate what hardware are you using, and the code you are using?
i cant understand the problem exactly 😉
(3,802 Views)
@SomeGuy wrote:
Hi all!
How you are entering the PID values in MAX I don't understand the relation. If you want to give the value to the PID module through code you can do so by writing it to a file and reading to the PID values so even when you restart the value will be stored into the file. Please explain a bit more to get the required solution.
(3,794 Views)
Sorry, my question was stupid. What I actually should''ve asked is: How do I get MAX to save my settings? When in MAX, I go to Calibration > Servo Tune > Control Loop tab. When I edit the settings there, the changes don't persist beyond a restart of the computer. Why is that and how can I actually save them?
(3,757 Views)
and you don't have a "save" or "save to all axis" button?
What hardware are you using?
(3,749 Views)
Yes, there is a save button. Two, actually. "Apply" and "Apply all". I just found out that the settings do in fact stay in MAX, but they aren't applied automatically. So everytime the system starts, the device shows its "default" behavior. So I need to open MAX and press "Apply all".
The computer has a PCI-7344 4-Axis Stepper/Servo Controller card. The axes are Steinmeyer OFD axes.
(3,746 Views)
