07-21-2005 11:04 AM
07-22-2005 01:21 AM
You can use the application class property Remote Panel:Connections To Clients to get some data about the client connected to your VI.
To get it, create a property node (Application Control palette) and then click the node and find the property. It's an array of cluster.
Another option, depending on you're interfacing with the web server, is to get the data from the web server.
07-22-2005 03:38 AM
07-22-2005 03:54 AM
07-22-2005 08:39 AM
i just published my VI to make it remote front panel that just what i know about remote front panel. how can i access a property i do nt know i would be really thank ful if u write me some more detail or any link on the topic. u said i can call the property from VI i do not know how to do this kindly give ur suggestion.
07-22-2005 09:46 AM
07-22-2005 10:05 AM
07-23-2005 04:59 AM
07-23-2005
03:58 PM
- last edited on
12-03-2025
02:12 PM
by
Content Cleaner
Well, if you don't know how to find the Application Control palette, then I would say you're not in a good position on the LV side, since opening a palette to place a VI on the diagram is pretty much the most basic operation in LV, and the palette names are listed on the top of every palette. This specific palette looks like a hand holding a platter with the LV logo on it.
If you are a beginner in LV, try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide.
07-24-2005 10:56 AM
Well You r right iam a beginner inlabview just about 3 months but thanks ot GOd during this time i have learn a little bit of labview and have wrote an application that acquire data and can also update it on mobile. however i do admit my knowledge in labview is not very much an di need people like u to guide me more. about the palette i can off coarse paste vi both in control palette and function palette these are the two palette that i have come across .being an MCP in miccrosoft product i know that a object do have properties and i also used the properties of some of control palette but i confess i am unable to find the application node property there iam search that pallete and will off coarse read your send link too
Thanks.
