Explorer CD ROM in windows Explorer
I have made autorun program in Lab view with following option:
1. Install Software
2. Read Help
3. explore the CD
So, i want to explore the CD in windows explorer. I m able to open the explorer but it shows me my documents. Instead of that i want to explore CD. I have opened explorer by using system exe vi.
Kaustubh
VC (Pune)
INDIA
(2,711 Views)
Just append the path that you want explorer to default to to the command line
e.g.
explorer.exe d:\
(2,708 Views)
I'll remind you again that the program on the CD needs the run-time engine in order to work. In your computer it works fine, because you have it installed, but if you take it to another, it won't work, unless it has it installed.
I remember threads dealing with running an executable with installing the RTE. As far as I can remember, it involved copying one of the directories from the LV folder and making sure your EXE was in the same directory. If you need this, try searching for combinations of USB, CD, stand-alone executable, run-time and so on. If you find anything, post a link here. It would be nice to see.
___________________
Try to take over the world!
(2,698 Views)
