serial write finished time
Hello
briefly  this is what i need to do .
1-Use Serial Write palette
2-Waite until all data are sent
3-Do some thing
How can i do number 2 ?
Best Regards
Message 1 of 22
(4,914 Views)
You need not worry, once it will write all data then only it will execution will proceed further.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 22
(4,897 Views)
just want to add that if you want to read a possible answer from the device after writing to it,
that there might be an inherent waittime until the answer bytes are available in the buffer.
:cheers: & good luck
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 22
(4,873 Views)
In addition you need to remember that LabVIEW is an inherently parallel language so you need to make sure your dataflow is correct.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 22
(4,863 Views)
That's not really true.  The write function says it is done once the data is sent to the UART buffer.  That does not mean that the data has all been sent, just that is is primed to be sent.
Message 5 of 22
(4,845 Views)
So how can i be sure .
because of different baud rate i can't add wait time .
and it's not really good way .
Message 6 of 22
(4,836 Views)
What are you trying to communicate with?  Can you ask it for a response?  Once you get that response, you know you are ready to move on.
If that is not an option, you could use a loop back so that you use another port to read the data.  Once you read it all, you know it has been sent.
Message 7 of 22
(4,823 Views)
Could i do st like this :
(baud rate /8)*data length = wait time
Message 8 of 22
(4,811 Views)
That will give you the minimum time to write the data.  However, serial (RS-232) communications are asynchronous and there is no guarantee that all bytes are transmitted without delay. Typically no delay occurs but it could happen. If the communications protocol includes any handshaking, delays could be arbitrarily long.
What is the reason you need to wait? What is the device at the other end?
I think crossrulz is right. You need a response or some form of monitoring to be sure.
Lynn
Message 9 of 22
(4,794 Views)
there is reponse .
these are all for calculate time out .
Message 10 of 22
(4,786 Views)
