serial scan until \r\n
I have made the changes you suggested but I still don't think I am using the case structure correctly...
Message 11 of 34
(2,247 Views)
Make the 0 case display 0... --> that means that there was a EOL found anywhere within the string. A -1 will mean that no EOL was found.
Edit: Sorry, I told you wrong before. I don't think I've had enough coffee in me yet. Smiley Wink
Message 12 of 34
(2,233 Views)
One more thing, make the 0... case default.
Message 13 of 34
(2,231 Views)
Okay, I made the 0 case the default. Could you specifiy what you mean by "display?" I don't want to write a 0 to the text file.
Message 14 of 34
(2,226 Views)
No problem.
On the zero case, place your cursor next to the 0 and add two peroids, not three, so it displays like the image below.
Message 15 of 34
(2,217 Views)
Finally someone on here who is blatently clear! lol
I made the change but unfortunately no data is written to the text file.
I clicked on the wire coming from the offset past match while the VI was running and it displayed a probe dialog window. The window displayed the values of going through the offset past match wire and I never saw a 0 or -1. It jumped around from 81 to 24 to a few other numbers.
Message 16 of 34
(2,214 Views)
These forumns have been giving my browser fits. Plus it would help if I could a) type correctly, and b) get the syntax right.
Post your vi, not the images.
Message 17 of 34
(2,210 Views)
Using google chrome?
This VI is meant to get serial data from a GPS module and print the NMEA strings to a text file for post-processing. I don't think you would be able to get anything useful out of running the VI. I won't deny you it though.
Message 18 of 34
(2,206 Views)
@Eric1977 wrote:
I like to use the Greater Or Equal 0 function to make things a little more clear.  It also helps that I use the structure label to say what question is driving the case structure.
Message 19 of 34
(2,201 Views)
Tried that too. I think a better way to approach this would be this. Read the data in one byte at a time. Don't start to read until a $ is encountered. After a $ has been seen, start to print to the text file. Contine printing until a \r\n is seen. Go to a newline and repeat the process. Attached is the output from the last attempt using the greater than or equal function.
Message 20 of 34
(2,196 Views)
