serial reading/writing posibility
hi everyone,
I am using labview to send command and received respond from a linear stage through serial port.  Since  I need to get the positional reading while the stage is in motion, I have to keep asking the stage to send back the reading.  The question I have is that if i keep  one serial reading runing, is that possible to keep using  srial write function to send command as the same time? If that is possible, is there anything particular that I need to pay attention to ?
thanks
(2,972 Views)
No, the Write/Reads will have to be done serially. You will have to interupt your position loop briefly in order to send something else.
(2,957 Views)
All right, I get it.  One more question,
 when the serial read  function reads a terminate character( so the serial read function stop reading),  is it possible to stop a while loop at the same time? If possible, how? can anyone help me ?
thanks
Message Edited by zhao.lin on 05-17-2008 07:14 PM
(2,951 Views)
Hi zhao.lin,
yes it is possible. Search in the received string for you termination character, if you found it, then you can stop the loop. See the attached picture, it shows one solution.
Mike
Message Edited by MikeS81 on 05-18-2008 08:07 AM
(2,939 Views)
Thanks mikes. One more quesiton, I am not sure what specific function that you are using in your picture. Can you tell me that function is that?
thanks
(2,910 Views)
Hi zhao.lin,
it is "search and replace string".
Mike
(2,902 Views)
