serial communication, unreadable output
Accepted by denis1981
You need to make sure the settings you use in LabVIEW match the ones that your microcontroller is using.
Message 11 of 14
(1,637 Views)
thanks...
I digged into the uart settings and found that the baud rate was indeed incorrect...
Thank you much evebody
Message 12 of 14
(1,630 Views)
What was the correct baud rate?  I'm surprised you got anything at all without an error.
Message 13 of 14
(1,626 Views)
115200
see attachement, got it working
Message 14 of 14
(1,623 Views)
