serial communication Problem
ok i'm tring to communicate using the serial port to a device when an A1 hex is sent it turns on and led and an A0 hex turns it off.
i have tried using several different methods,most of the examples here, and none are working.
i have logged the seriel port and the data is there according to the logger.
i can use vb to to turn the led on and off.
Public Sub LedOn()
Writeled ("A1")
Call DelaySeconds(0.25)
End Sub
any idea's as to why it won't communicate??
(3,246 Views)
Are you using VISA calls or the older traditional Serial interface?
rjmiller
(3,246 Views)
yes i am using visa calls
(3,246 Views)
OK, so on your front panel, you have the VISA handle and internally a call to VISA Open which the output handle is piped to the VISA write (for example).
On the front panel can you see ASRL:: anything?
If not, can you run VISA interactivly without LabView - should be under the Programs->National->VISA->
You can also run MAX to see the COM ports as welll.
Are they present?
rjmiller
(3,246 Views)
If you can see the ports in VISA, try checking the termination character in the VISA initialisation. If the instrument you're communicating with doesn't expect a termination character, this might be the reason for the problem.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,246 Views)
You mentioned that the instrument requires hex. If you need to send 0xA1, then right click on your string control/indicator and select hex display, then type in A1. If you are in normal display, then you are sending an ASCII 'A' and '1', which is 0x4131 in hex.
(3,246 Views)
