Problem with LvVariant.cpp on line 696.
I recieved this error and LabVIEW crashed when attempting to connect to a running VI using AppletVIEW. What is causing this and how is it fixed?
(2,585 Views)
Thank you for contacting National Instruments.
Do you recieve this error at any time when not using the AppletVIEW software? We have several reports of similar issues associated with Datasocket connections, which is a TCP/IP protocol that LabVIEW can use. However, these issues were very specific to Datasocket and were resolved for LabVIEW 6.0 and later.
However, because the AppletVIEW connection is made via TCP/IP, I am curious as to whether it may be a similar problem. Since AppletVIEW is manufactured by a different company, Nacimiento (http://www.nacimiento.com/AppletVIEW/), I do not have the software available for testing. Have you been able to contact Nacimiento's support to see if they have seen similar problems?
If you were able to reproduc
e this with a small VI separate from AppletVIEW (perhaps using simple TCP connections), I would be happy to reproduce it here and pass it along to our developers if necessary.
Please let me know how I can be of further assistance. Have a great day!
Liz F
(2,585 Views)
