sequence structure replacement
thanks!
The rest could probably be removed if you used the Error Cluster to force sequential execution like you are supposed to do.
this does not make sense to me.. do you have an example?
have a nice weekend
Message 11 of 25
(2,060 Views)
Have a look at this NI newsletter.  It covers the overuse of stacked and sequence frame structures and how to replace them.
Message 12 of 25
(2,054 Views)
@idjuven1 wrote:
thanks!
have a nice weekend
Here's an example...
The error cluster forces sequential execution because of DATA FLOW!
=== Engineer Ambiguously ===
Message 13 of 25
(2,046 Views)
Even one SSS or FSS is overuse...
Message 14 of 25
(2,015 Views)
thanks so much!
Message 15 of 25
(2,006 Views)
I  (mildly) disagree -- one sometimes needs to "tie" a Timing function (such as Wait, or Clock Read) to a specific point in the code, often between two functions connected by an Error Line.  "Wrapping" the Time function in a single Frame Sequence and forcing the Error Wire to "tunnel" at least into the Frame is an "obvious" and "intuitive" way to say "Do this now".
Message 16 of 25
(1,995 Views)
Sure, but a sub VI would be a better option. Or a case structure, so the wait is skipped when there is an error. I use them (rarely), but usually they get refactored out sooner or later.
Message 17 of 25
(1,988 Views)
Agree 100%.  My "Delay (ms)" function follows me around "like a little puppy" (quick, who says that?).
Message 18 of 25
(1,984 Views)
@Bob_Schor
Even that google will find (first hit at the moment).
Message 19 of 25
(1,981 Views)
Not really needed now since LabVIEW 2017 with the introduction of the Stall Data Flow.vim.
Message 20 of 25
(1,968 Views)
