‎08-09-2006 11:53 AM
‎08-09-2006 11:55 AM
‎08-09-2006 02:09 PM
‎08-09-2006 02:36 PM
I think it depends on what kind of DAQ board you have whether there is calibrate tab or not. For example, I don't think you can calibrate the low-end USB DAQ devices.
If I understand you correctly, calibration is separate from converting the voltage readings to some other units. The latter is accomplished with scaling and some conversions can be done automatically. If you could explain what kind of DAQ card you are using, sensors, conversions necessary, etc. it would help to provide a more detailed answer.
‎08-09-2006 02:55 PM
‎08-09-2006 03:54 PM
