sensor values not updating and showing on indicators
hello friends,
my input string values are not updating on meter and also their is no deflection on indicators
help me with necessary changes and steps
thankyou
(4,504 Views)
Hi abhi,
you need to parse your received string more carefully!
Start debugging your VI by using probes, then change the conversion part…
- Why do you use BytesAtPort, when your serial communication uses a TermChar?
- That string looks very familiar to me: Can't you discuss your problem with your collegue(s)?
(4,499 Views)
why aren't indicators not showing any change and even i have misplaced data appearing i.e temperature reading displays on humidity.
sorry but no collegues are available who are familiar with labview
what changes i have to make.
please update the necessary changes in VI
thank you
(4,484 Views)
Use "Scan From String" function efficently, be carefully while connecting format sting input.
Amit
CLAD
(4,469 Views)
Hi abhi,
convert your strings more carefully!
One possible solution might be:
(4,456 Views)
Duplicate of http://forums.ni.com/t5/LabVIEW/how-to-display-array-values-on-indicators/m-p/3135587
Still have not paid any attention to answers there. Why would the poster pay attention to answers on this thread? Stop asking if you won't follow the directions that have been given.
(4,449 Views)
If the values are showing on the indicators but they are not changing, it is because you are looking at the first line of the concatenated string ever time the loop runs.  You never look at the second or third line.
aputman
(4,421 Views)
