project window is closing unexpectantly
Dear Collegoues.
I met the following ptoblem:
I use Labview2014 with windows 7. I built FPGA with RT project that is running correctly.
However, when i am starting the project, the project windows (with whole vi's and definitions)  is appearing for a second and unexpectantly disappear. Looks like closed. Every time i want to run the project it happens. I suspect that the project window is not closed. But i do not have any acce'ss to project and not allowed to run my vi's.
After about 15-20 attemts to start, i obtain proposition for vi recovery and the project is starting to run.
I tried to reinstall the labview, without any results.
May be some one met the same problem before?
Thank you a lot in advance.
(3,081 Views)
This seems like a rather strange issue. You may want to consider performing a force reinstall through the command prompt.
'Force Reinstall NI Software from the Command Prompt in Windows'
http://digital.ni.com/public.nsf/allkb/ADD22E807D5A12AD862579EC00760F79
It is not uncommon for a force reinstall to clear up peculiar issues that a normal reinstall does not.
(3,031 Views)
