sending floats over uart
I have a custom board with a uart connect to a PC and labview.  The board is generating 32 bit single precision floating point data.  I would like to send the 32 bits of the floating point numbers as bytes and reconstruct them into a single precision floating point number in labview.  Labview does have a concatenate byte\word vi but the result is just a 16bit integer.  I don't know how to tell labview to represent my final 32 bits of data as a float.
In C i could regroup my 4 bytes and then make a float* that pointed to the low address byte.
Any help on this would be greatly appreciated.
(3,597 Views)
You would use the Typecast function to convert to SGL.
(3,591 Views)
thanks a bunch!!
(3,547 Views)
