06-19-2010 10:15 AM
I have a custom board with a uart connect to a PC and labview. The board is generating 32 bit single precision floating point data. I would like to send the 32 bits of the floating point numbers as bytes and reconstruct them into a single precision floating point number in labview. Labview does have a concatenate byte\word vi but the result is just a 16bit integer. I don't know how to tell labview to represent my final 32 bits of data as a float.
In C i could regroup my 4 bytes and then make a float* that pointed to the low address byte.
Any help on this would be greatly appreciated.
06-19-2010 10:34 AM - edited 06-19-2010 10:35 AM
You would use the Typecast function to convert to SGL.
06-21-2010 06:17 PM
thanks a bunch!!
