03-21-2022 11:09 AM - edited 03-21-2022 11:10 AM
I'm trying to send a string from an arduino gsm board to an labview server. From arduino board i think everythink is ok, i specified ip adress and port number, the problem is that it can't connect to the labview server and i don't have any more ideas where can be the proble.
I tryed with hercules to listen o port and it works fine, i received the data from arduino.
I leave here the code i used and the VI for server.
// libraries
#include <MKRGSM.h>
#include <Arduino_MKRENV.h>
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = "1234";
// APN data
const char GPRS_APN[] = "live.vodafone.com";
const char GPRS_LOGIN[] = "live";
const char GPRS_PASSWORD[] = "";
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
uint8_t pachet[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
// URL, path and port (for example: example.org)
char server[] = "141.85.162.154";
char path[] = "/";
int port = 5901; // port 80 is the default for HTTP
void setup() {
// initialize serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
if (!ENV.begin()) {
Serial.println("Failed to initialize MKR ENV shield!");
while (1);
Serial.println("Starting Arduino web client.");
// connection state
bool connected = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (!connected) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
connected = true;
} else {
Serial.println("Not connected");
delay(1000);
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port)) {
Serial.println("connected");
// Make a HTTP request:
// client.print("GET ");
// client.print(path);
// client.println(" HTTP/1.1");
// client.print("Host: ");
// client.println(server);
// client.println("Connection: close");
// client.println();
client.beginWrite();
client.write(pachet, sizeof(pachet));
client.endWrite();
} else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
void loop() {
// read all the sensor values
float temperature = ENV.readTemperature();
uint16_t word_temp = temperature * 100;
uint8_t high_word_temp = word_temp >> 8;
uint8_t low_word_temp = word_temp;
pachet[1] = high_word_temp;
pachet[2] = low_word_temp;
float humidity = ENV.readHumidity();
uint16_t word_hum = humidity * 100;
uint8_t high_word_hum = word_hum >> 8;
uint8_t low_word_hum = word_hum;
pachet[3] = high_word_hum;
pachet[4] = low_word_hum;
float pressure = ENV.readPressure();
int16_t word_pressure = pressure * 100;
uint8_t high_word_pressure = word_pressure >> 8;
uint8_t low_word_pressure = word_pressure;
pachet[5] = high_word_pressure;
pachet[6] = low_word_pressure;
float illuminance = ENV.readIlluminance();
uint16_t word_illuminance = illuminance * 100;
uint8_t high_word_illuminance = word_illuminance >> 8;
uint8_t low_word_illuminance = word_illuminance;
pachet[7] = high_word_illuminance;
pachet[8] = low_word_illuminance;
float uva = ENV.readUVA();
uint16_t word_uva = uva * 100;
uint8_t high_word_uva = word_uva >> 8;
uint8_t low_word_uva = word_uva;
pachet[9] = high_word_uva;
pachet[10] = low_word_uva;
float uvb = ENV.readUVB();
uint16_t word_uvb = uvb * 100;
uint8_t high_word_uvb = word_uvb >> 8;
uint8_t low_word_uvb = word_uvb;
pachet[13] = high_word_uvb;
pachet[14] = low_word_uvb;
float uvIndex = ENV.readUVIndex();
// print each of the sensor values
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
Serial.print("Humidity = ");
Serial.print(humidity);
Serial.println(" %");
Serial.print("Pressure = ");
Serial.print(pressure);
Serial.println(" kPa");
Serial.print("Illuminance = ");
Serial.print(illuminance);
Serial.println(" lx");
Serial.print("UVA = ");
Serial.println(uva);
Serial.print("UVB = ");
Serial.println(uvb);
Serial.print("UV Index = ");
Serial.println(uvIndex);
Serial.print(" ");
Serial.println(" ");
for(int i=0; i<28; i++)
// if(pachet[i]==0)
// pachet[i]=1;
Serial.print(pachet[i]);
Serial.print(" ");
Serial.println();
Serial.print("dimenziunea pachetului este");
Serial.println(sizeof(pachet));
// print an empty line
Serial.println();
// wait 1 second to print again
delay(1000);
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for (;;)
03-21-2022 01:36 PM
Hi Dummson,
Unfortunately you forgot to attach that VI…
Can you create one more VI that does the same as the Arduino should do: send some data to your "LabVIEW server" (whatever that is!?)?
