sending HEX code
I want to send a fixed HEX code without indicating it in front panel. It is just by a switch the hex data is send. The front panel HEX indicator should not be visible. How to do it.?
(3,876 Views)
You need to be much more specific.
  • What is HEX code? (e.g. hexadecimally formatted string consisting of the characters 0..F, binary string, U8 arrays, etc.)
  • What is "send"? Send to where? What data format does the receiver expect?
  • What does an indicator have to do with all that? An indicator is just a purely cosmetic feature that allows you to see the data in a wire on the front panel formatted in a convenient way. It has no influence of the underlying data in the wire). If you don't need the indicator, just delete it!
It usually helps if you could attach a simplified VI containing typical data in controls as default values.
(3,861 Views)
You could use a numeric constant (which only appears on the Block Diagram, and whose Display Format you could set as Hexadecimal) or a Numeric Control on the Front Panel that you make "invisible" (by finding the Control on the Block Diagram and choosing the right-click option "Hide Control").
(3,841 Views)
I thought he was talking about an indicator (data sink). A diagram constant is a replacement for a control (data source). (...of course if the code is peppered with local variables, the distinction is a bit more blurred :D)
I guess we need to wait for more details on what the actual problem is and where the data is coming from. 😉
(3,832 Views)
