send command to linear ccd
Hi
i've problem with send command to linear ccd.(tcd1304ap toshiba). MAX can detect the ccd but i don't know how send these commands to ccd.
(4,302 Views)
How is this linear CCD connected to your PC?  Serial port?  Digital input/output signals in a DAQ card?
(4,276 Views)
the ccd connected to the pc by serial port.
(4,257 Views)
Accepted by arsham.hamidi
did you test your ccd comment by other softwares like hyper terminal , versaterm
,putty or x-ctu ?
it is better to check your comments working correctly before jump in labview programming
(4,248 Views)
Then you can use VISA to read and write commands to the serial port.  There are examples in LabVIEW.  But you are better off searching the forums for messages about serial port communication.
(4,234 Views)
thank you for your help,i finally find out what was my problem
(4,154 Views)
