send command from loop to start a parallell loop
Hallo!
In my mainloop that I want running all the time, there is a boolean
or something that starts a parallell loop to the main! I dont want
the second parallell loop to run all the time, only on command! And when the
second loop is done, only the main continue running. Then the second parallell
loop is again ready to run on the "command".
Is there a way to fix that?
Thanks, Fred
(3,449 Views)
Hi Fred
You could use Notifiers. This also allows you to exchange a value between your two loops.
Just have a look at the attachment.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,437 Views)
Unless you really have severe timing problems, a nearly empty timed loop running in parallel does not add a significant pressure over the processor.
Anyway, there is a positive answer to your question. Use an occurence node (belong to the synchronization vi's sub-palette). As you will see in the attached sub-vi, that belongs to more advanced programmation techniques, although I'm not sure that the example is optimal 🙂
Chilly Charly    (aka CC)
(3,435 Views)
Hi Charley,
I was interested in the question but I could not open the zip file,could you please post the vi again???
Regards.
ohiofudu.
Certified LabVIEW Architect
Certified TestStand Architect
(3,426 Views)
Back with .zip...
CC
(3,410 Views)
thanks for the tip
(3,345 Views)
thanks!
I choose two parallell loops and hopes the processor handles that. The second loop
runs empty most of the time.
(3,344 Views)
