selection one or multiple task
i'am working with labview 2013 and I would like to select on the front panel one or several task of input analog measure, i know how to do with one task but i don't know how to do with multiple task, could i merge two task in one?
Thanks!
Message 1 of 8
(4,137 Views)
What exactly do you mean by multiple tasks? All analog inputs (for example) would be a single task. You can merge multiple channels into a single task. No merging is required if the analog inputs are setup the same.
Please clarify exactly what you have on your front panel.
Message 2 of 8
(4,132 Views)
Some channels are associated with a device (for example Ai0:6 to device 1 and Ai7:10 to device 2) and i want to have the possibility to select what device i want to "measure" by selecting it very simply on the front panel (for example with a single/multiple task selection system)
thanks
Message 3 of 8
(4,122 Views)
A Boolean wired to a select function will permit switching between 2 different physical channel controls.
Message 4 of 8
(4,113 Views)
hi,
The task i'am talking about is the task of the DAQ function "create a virtual channel".
thanks
Message 5 of 8
(4,109 Views)
That's what I assumed when I suggested the select function.
Message 6 of 8
(4,104 Views)
Accepted by topic author
yes i think i could do what i want with this solution, i just had difficultie to find the select function (beginner with labview)
thanks a lot
Message 7 of 8
(4,095 Views)
thanks
And your problem is what exactly?Smiley Wink
"Should be" isn't "Is" -Jay
Message 8 of 8
(4,090 Views)
