select function not returning what's expected
My select function is always returning the enum wired to false despite the input being true. Can anyone see why this may be happening? Possibly corrupt? I am doing this on a cRIO not the PC but it's a fairly simple thing to do.
(2,813 Views)
Is enum a type def?  If not you could have different versions of enum.  I've done it before and things got a bit confusing.  Smiley Very Happy
Two tunnels exactly on top of each other?
(2,803 Views)
Are you sure that the case you are showing is the one executing?
(2,793 Views)
self = idiot -> true. I was in the correct case but the case was stuck in a timeout so it never exited, thus never switched the final boolean to true.
(2,791 Views)
Well next time try using the Expect function inside of the select. Smiley Tongue
Don't feel bad. I once had to post a sample VI because I could not get a control to operate, only to have Dennis tell it was disabled. (that is a double-duh).
But while we are the subject of following the wrong track...
In LV 2010 RT there is a bug that prevents probes from updating which can (well it did) lead me into la-la-land trying figure out why the case never ran.
So if you are debugging 2010 RT and a probe is not updating and you wonder if the code is being executed, don't trust the probe, create an indicator.
Ben
(2,773 Views)
