search string
I am trying to retrieve all the filenames out of this string, and save them into an array.
"#LSCRIPT: "netcmd.pyo",9643#LSCRIPT: "main.pyo",1261#LSCRIPT: "filereader.pyo",3022#LSCRIPT: "strategy.pyo",3948#LSCRIPT: "util.pyo",2177#LSCRIPT: "states.pyo",1073#LSCRIPT: "stores.pyo",3136#LSCRIPT: "serialmgr.pyo",7975#LSCRIPT: "netsm.pyo",8429#LSCRIPT: "netmodem.pyo",4915#LSCRIPT: "netmsg.pyo",4965#LSCRIPT: free bytes: 1956068"
Can't seem to get the correct scan from string expression.
Any advice?
Goose
Message 1 of 9
(5,096 Views)
Can you post what you have did so far, that will help to support further.
Mathan
Message 2 of 9
(5,092 Views)
Assuming that...
The filename is always lower case letters, with extension .pyo,
the following regex would work - use Match Pattern for the search...
[a-z]*[.]pyo
If you want to be sure to find the filename in quotes, add \" at the beginning and end of the regex, but you would then need to remove the quotes from the matched string.
You'd loop, progressing through the string,  until there is no match.
Rod.
Message 3 of 9
(5,083 Views)
Hi goose,
I would do this in two steps:
1) use "spreadsheet string to array" with "#LSCRIPT:" as delimiter to produce a 1D array of strings
2) split each string at the "," to separate filename and size(?)
2b) check for errors as the last string will not deliver correct results...
Message 4 of 9
(5,079 Views)
Message 5 of 9
(5,060 Views)
Thanks for all the great replies!
Is it possible to use 1 search string, which searches for filenames ending in both .pyo and py ?
Cheers
Goose
Message 6 of 9
(5,043 Views)
Do you want them seperated or in the same list?
Tim
GHSP
Message 7 of 9
(5,039 Views)
same list
Message 8 of 9
(5,033 Views)
Accepted by topic author morngoose
Try this
Tim
GHSP
Message 9 of 9
(5,027 Views)
