how to design a main menu?
hi LabVIEW-users,
i'm working on labview for about 2 weeks and have made some simple VIs for voltage measurement.
now i want to put these VIs (3) together in one application (.exe) with a kind of main menu where i can
choose the VI i want to use. here's a pic to help understanding what i want to do:
each VI works on its own (no interacting with another VI, no "value-sharing").
and i need some kind of "back-button" to come back to the main menu to choose another VI.
so my question is how to create this type of menu,
i'm open to every kind of support...explainations...examples...tutorials...hints.
thx,
philipp
Message 1 of 15
(4,640 Views)
Hi fr33k,
Which version of LV are you using? Pro, Base, Student?
Message 2 of 15
(4,619 Views)
ahh sorry, i knew i forget something.
i use LabVIEW 8.6 - Base Development System
Message 3 of 15
(4,615 Views)
Are you talking about creating a run time menu?
Message 4 of 15
(4,607 Views)
Since you don't have Event Structures, I can think of this only.
You could use the paths to be relative and connect the error panes. To reduce CPU cycles you could put in a wait node in the while loop. I dunno if this is the best way or not. Hope it helps.
Nitin
Message 5 of 15
(4,606 Views)
Is this what you are looking for? Please place your subvi's inside the respective cases in the case structure
Message 6 of 15
(4,597 Views)
@muks: due to the fact i'm new with LabVIEW i don't know exactly what a "runtime menu" is?! but i want the menu to work in an application. maybe i can make the menu in the projectexplorer?
@NitinD: thx for your solution, i will try to make it in the next hours and give a feedback.
Message 7 of 15
(4,592 Views)
Message 8 of 15
(4,573 Views)
You can also go to vi properties -->windows appearence--> customize--> (CHECK) show front panel when called and close afterwards.
Message Edited by muks on 09-22-2009 04:30 PM
Message 9 of 15
(4,571 Views)
Message 10 of 15
(4,564 Views)
