search in a string
Hallo Guys,
      I have an array of strings (list of the names of the mesurements, For example, PVE_12S1, PVE_12S2, PVE_12S3, PVK_12S1, PVK_12S2, PVK_12S3, PtVE_12S1, PtVE_12S2, PtVE_12S3). As an out put I have to group the names ending with same number (for Example i should the out put as PVE_12S1, PVK_12S1, PtVE_12S1) when I Enter 1 as my desired number. Hope you guys can help me. Thanks in advance
(4,262 Views)
It seems to me that the "ID" is always prepended by an underscore ('_'). If that is true for all strings, i would iterate through the array, look at each string for anything following that underscore and sort the elements appropriately.
I have the impression that the result should be a complete, independent array of strings. So "sorting" refers to "build a new array with only those elements which meet the search requirements".
Norbert
Norbert
Expert: Geometry
(4,255 Views)
Thanks for the instant reply. But there are some names (PVE_12D1, PVE12D2, PVE_12D3) where the PVE_12D1 should also come into my out put. Thanks
(4,248 Views)
Accepted by topic author harisskriss85
What have you tried?
Jim
(4,231 Views)
Thanks alot.
(4,225 Views)
Alot didn't help you; I did. 😄
http://hyperboleandahalf.blogspot.com/2010/04/alot-is-better-than-you-at-everything.html
Jim
(4,218 Views)
