search files which filename contains a speicific string
Hi
I'm lookng for a way to find all files in a directory which part of filename contains a specific string.
e.g.:
string = hello
files;
- 1hello2.txt
- 22he45.txt
- gehello42353.txt, ....
The result should be either an index or the complete filename that matches. In the example I'd found index 0 and 2, or 1hello2.txt and gehello42353.txt.
Actually I have the list of the files with the "recursive list.vi".
Any suggestions are welcome.
Thanks for your precious help
Yves
(8,408 Views)
Accepted by topic author Yves
You can use List Folder - function with *hello* -pattern.
From there you get filenames, which include that specific pattern.
If you allready have list of files:
- use Scan string for tokens in a for loop and if token index != -1, then you can add that array index to the list.
I´m sure there are better ways to do this, but nothing I can come up with quickly.
(8,406 Views)
